bad gas milage
Old Mar 31, 2012 | 03:07 PM
Its rare to hear a complaint about felpro gaskets. I used one on my 95 EX valve cover and don't remember having any problems with it.
I guess, when in doubt, go with the honda parts. Some of their parts are about the same price as aftermarket. Some are way too expensive compared to aftermarket, IMO.
Old Mar 31, 2012 | 03:09 PM
Mosier.36's Avatar
awesome, going to change it after work.
Old Mar 31, 2012 | 03:25 PM
Mosier.36's Avatar
i ended up getting the fal pro, I'll let you know how it goes lmao.
Old Apr 27, 2012 | 01:02 PM
Mosier.36's Avatar
I changed:
Air Filter
Rotor
Cap
Wires
Plugs
Fuel Filter
I'm still getting around 18mpg. I also have a rather rough idle, I adjusted the low speed idle valve? (I think thats the right name). I no longer have a surging idle, but it drops fairly low around 200 then catches it self and comes up to 600-800 range.
What should be my most logical next steps?
(BTW fal pro fit fine, not leaking any oil from the valve cover anymore)
Old Apr 27, 2012 | 02:02 PM
Brahms's Avatar
Don't know where you live, but if there's an emissions check place nearby you can get them to run an exhaust test to see if you have an injector/O2 sensor problem. Might you have a vacuum leak? Bad PCV valve? What's your compression like? These are all cheap/free checks that can help pinpoint a problem before you start throwing parts at it. Remember to look for the simplest, cheapest problems first, instead of doing like I do and assume the worst. . .
Old Apr 27, 2012 | 02:04 PM
I would clean the inside of the throttle body and both sides of the throttle plate. Use throttle body cleaner and an old toothbrush.
I would also remove the IACV and clean the screen. It can get plugged up over time with carbon.
I would reset the ECU and TCU by pulling the 7.5 amp backup/radio fuse in the engine bay fuse box for a minute. Start the car when cold and allow it idle and reach operating temperature.
I would set the base idle the proper way. In the common diy thread on top of the gen tech help forum, there is a link to setting the base idle. You may want to check for engine and transmission codes as well. That common diy thread has a link for checking codes.
Old Apr 27, 2012 | 02:44 PM
  #17
If you've never replaced the O2 sensor, it should be on your maintenance list. This has major effect on fuel efficiency and can degrade before setting CEL on. Denso part (I think OEM) is available for about $35.
Old Apr 27, 2012 | 03:51 PM
  #18
Mosier.36's Avatar
thanks, I'll try these and see what happens, it's not like putting new parts on and and cleaning it could make it worse lol
HighwayStar
Mar 8, 2012 08:01 PM
jrogers04
Feb 14, 2009 04:51 PM
danjel
Apr 21, 2007 01:45 PM
thunder_x
Dec 15, 2005 11:44 PM
craiglawless
May 3, 2005 02:20 PM
