Battery Bad?
Old Sep 5, 2009 | 11:16 PM
churritos567's Avatar
Default Battery Bad?
okay i have a 2001 honda accord v6 and basicly the tach bounces from 500prm-300rpm then back up agian and it repeats it does it when the headlights are on or when the ac is on when idling and the dash lights would dim and when driving the needle will be bouncing at any rpm. could the battery be bad? any ideas would help thanks!
Old Sep 6, 2009 | 01:32 PM
If engine speed is normal (700-800 rpm) when tach is bouncing, I would suspect a bad alternator (low voltage output). Have an alternator and battery check performed.
If idle speed is actually very low (300-500 rpm), the problem might occur under heavy electrical load; inadequate voltage w/ a good alternator. In this case you need to clean the idle air control valve, throttle plate, and throttle body bore to restore idle performance.
Old Sep 8, 2009 | 08:13 AM
If the engine RPM is actually bouncing, then you can go over all the normal things for surging idle.
Old Sep 8, 2009 | 03:54 PM
okay i the alternator tested at autozone and they said its bad so i got another one from the junkyard and its still doing the same thing. should i just get a brand new one?
Old Sep 8, 2009 | 05:06 PM
Maybe the junkyard one is bad too? I'd get a new one, but it's pretty easy for me to spend YOUR money.
giulio76
Dec 29, 2012 11:16 AM
bigalcalbisque
Sep 2, 2012 11:17 AM
cadams8221218
Jul 15, 2011 07:24 AM
gkt
Apr 10, 2008 07:06 PM
RoKnAzn
Jan 19, 2007 01:56 PM
