Battery light on after replacing starter
Old Aug 11, 2012 | 02:16 PM
zoid_99's Avatar
Default Battery light on after replacing starter
I just replace the starter on my 2003 2.4 Accord (what a PITA), I get everything back together and it started right up. But now the battery light is on. I've looked and I don't see any cables that i didn't reconnect. Any idea what to look for? I was super excited when the car started but now I'm bummed out because I assume the alternator isn't charging the battery.
I took a bunch of pictures as I was replacing the starter so I will soon post a blog hoping to help others.
Thanks again!
Old Aug 11, 2012 | 02:30 PM
There are a number of electrical connectors to be released when removing the intake manifold. Check that all are reconnected.
Old Aug 11, 2012 | 02:44 PM
zoid_99's Avatar
I did and they all look good. As it turns out I think the light was on because I had not entered my security code yet? THe light is now off. Does entering your security code clear the battery light when the battery has been disconnected?
Thanks everyone for the help!
Old Aug 11, 2012 | 06:00 PM
Not to my knowledge.
Old Aug 12, 2012 | 08:14 PM
zoid_99's Avatar
Well... I guess the battery light came back on while driving back from the store today because the car died a block from the house and it would't start back up. Batter dead. I've double checked the wires and can't find any that are loose or not connected. What are the chances that an alternator dies while replacing a starter. I'm thinking that s must be something I did to cause this?
Thanks.
Old Aug 13, 2012 | 08:26 AM
98013HWR's Avatar
Be sure to check the fuses in the fuse panels.
Old Aug 14, 2012 | 09:17 AM
zoid_99's Avatar
I didn't notice any fuses blown but I need to put a meter on them to check. I will do that this afternoon. I did notice that the battery light now never comes on. I believe that it used to come on when initially start the car like all of the other lights. I'm guessing this is a clue and it does sound like a fuse. THe odd thing is the first time I started the car after the new start the light was on, every since then the light never comes on.
Thanks...
Old Aug 14, 2012 | 11:50 AM
You can buy a battery voltage monitor from Amazon, Walmart, et al for < $20. Insert in cigarette lighter socket and monitor your battery voltage. This should tell if something is amiss w/ charging system.
Amazon.com: Equus 3721 Battery and Charging System Monitor: Automotive
Old Aug 14, 2012 | 09:01 PM
zoid_99's Avatar
I found the issue and it was a connector beneath the manifold that wasn't snug... Here's a recap of my starter adventures.
2003 Honda Accord Shade Tree
Old Aug 15, 2012 | 06:57 PM
Some nice pic's and good " how to" in there
Kevfarr
Dec 3, 2014 12:23 PM
claywhipkey
Jan 21, 2014 10:12 AM
salecalgary
Jan 21, 2013 01:35 PM
R0CKY
Dec 6, 2010 08:59 AM
dtv2031
Dec 24, 2008 06:07 PM
