Bent CV shaft?
I think I may have a bent CV shaft but how can I check to see if it really is? I have a kind of a "hopping" sensation that occurs from the right front corner mainly between 15-30 mph and it varies with speed. Wheels and tires are good as are the hub bearings. I suspect a bent shaft or spindle because the right front has hit the curb a bit hard a couple of times in the recent past. Any help is appreciated!
Now if it all stays the same, then I'd look deeper like wheel bearing, or bent control arm. An alignment shop would be needed for the control arm, but jacking up the RF, so it clears the ground and shake it in/out at 6 & 12, along with 3 & 9 o'clock.
Personally I've never seen a bent CV joint, or drive axle, but hub bearings, bent rims, and other items YES, I've seen those before.
I keep forgetting to mention that I've checked for many of those things. Tires and wheels are good and do not move when I try to shake them. Tires were rotated but no change. Control arms and ball joints are all new (replaced within the past year). I don't think it's hub bearings because a.) there is zero movement in any direction when I move the wheel (in/out, up/down, or side to side), and b.) there is no sound that would indicate a bad bearing. There's what seems to me like excessive play where the inboard joints enter the diff. assembly, but I don't know if that would cause the hopping. I believe it's a rotational component though, because the hopping varies up or down according to the speed of the vehicle.
