Bent CV shaft?
Old Oct 11, 2016 | 08:21 AM
BlackLX4's Avatar
Default Bent CV shaft?
I think I may have a bent CV shaft but how can I check to see if it really is? I have a kind of a "hopping" sensation that occurs from the right front corner mainly between 15-30 mph and it varies with speed. Wheels and tires are good as are the hub bearings. I suspect a bent shaft or spindle because the right front has hit the curb a bit hard a couple of times in the recent past. Any help is appreciated!
Old Oct 13, 2016 | 09:56 PM
The Toecutter's Avatar
Try swapping the right front tire and rim combo with the right rear. The idea behind this is to 1st see if the vibration is gone, or stays the same. If it goes away, then your problem lies in the rim, or tire (bent or out of balance, or out of round). Then you'll have to narrow it down by having it spun/balanced while it's being watched for anything out of normal (should run true and straight with no bouncing around up/down or side to side)
Now if it all stays the same, then I'd look deeper like wheel bearing, or bent control arm. An alignment shop would be needed for the control arm, but jacking up the RF, so it clears the ground and shake it in/out at 6 & 12, along with 3 & 9 o'clock.
Personally I've never seen a bent CV joint, or drive axle, but hub bearings, bent rims, and other items YES, I've seen those before.
Old Oct 14, 2016 | 07:19 AM
BlackLX4's Avatar
I keep forgetting to mention that I've checked for many of those things. Tires and wheels are good and do not move when I try to shake them. Tires were rotated but no change. Control arms and ball joints are all new (replaced within the past year). I don't think it's hub bearings because a.) there is zero movement in any direction when I move the wheel (in/out, up/down, or side to side), and b.) there is no sound that would indicate a bad bearing. There's what seems to me like excessive play where the inboard joints enter the diff. assembly, but I don't know if that would cause the hopping. I believe it's a rotational component though, because the hopping varies up or down according to the speed of the vehicle.
Old Oct 14, 2016 | 09:26 PM
It could then be a bad CV joint. Not sure which end of the shaft though. Usually you'll hear clicking when the outer goes bad, but the inner is usually quiet, until it goes (not very often).
Afnan
Nov 19, 2013 05:52 PM
Catcanski
Oct 31, 2007 10:53 AM
redsailtx
Oct 27, 2007 10:41 PM
ooo5
Aug 27, 2007 06:40 PM
Mpwr
May 12, 2006 04:14 AM
