big dilemma HELP!!
Old May 23, 2006 | 03:51 AM
cwalti's Avatar
Default RE: big dilemma HELP!!
....hmmmmm, try this....
Take him behind the barn and shoot him! :-)
Old May 23, 2006 | 04:34 AM
deserthonda's Avatar
ok,,,,,,,,plus are good. not the problem
new plug wires not the problem
new cap and rotor,,,,,,not the problem
YOU did use all Honda factory parts correct ???
injectors work........not the problem
compression ok........not the problem
mmmmmmm,, not too may things left,, going through the process of elimination that affects only 1 cylinder next thing i would do is to chk valve adjustment .
I forgot to ask you a very important question ...
Does engine have a miss on # 1 or just the code for # 1 misfire p0301 , comes up ??
if there is no miss on cyl # 1 ,, we are barking up the wrong tree ...it is not a mechanical problem ,,,
Old May 23, 2006 | 08:07 PM
trukid21's Avatar
i was about to do the valve adjustment but if that would be the case would'nt it be on the whole time even if i was at upper elevation? and yes its only the code#1 misfire PO301 comes on,but i also notice a poor fuel economy along with the problem when my CEL is on so i keep resetting the code. i ended up borrowing my friends code reader for now so i can reset the light everytime it comes on. and that seems to help with fuel economy problem.
saanich
Oct 17, 2009 05:47 PM
19Accord97
Mar 2, 2009 07:31 PM
finch13
Dec 2, 2008 12:11 PM
Jet_0928
Jul 18, 2008 02:07 PM
Dewd In The Newd
Jun 13, 2006 10:19 AM
