Black inside throttle body and intake
Old Apr 17, 2011 | 05:51 PM
stubs's Avatar
Default Black inside throttle body and intake
2000 Accord - 2.3 - auto trans - 120,000 miles
For the second time I had to clean the throttle body on the Accord my daughters share to keep the throttle from sticking a little in the closed position the first time the throttle is used in the morning. It will take a little extra push to pop it loose and then it's fine for the rest of the day. The first time about a year ago I just cleaned out the throat around the plate and it was fine.
This time I noticed there was some motor oil under the air inlet tube when I loosened the clamp from the TB. I lightly sprayed the interior and reached in to wipe it out and was coming up with a heavy deposit of oily black carbon grime from the inside of the TB and throttle plate. I took the throttle body off for a better look and a thorough cleaning. The inside is very fouled with the black grime as is the interior of the intake.
Is this engine suffering from excess blow by? It doesn't smoke on start-up or while running. I add a quart of oil on average between changes. Is there a component on these engines that's supposed to prevent all that oil from sucking up that needs to be serviced or replaced? I'm an old V-8 guy and drive a 70 swinger for my daily driver so I'm not as familiar with all the extra "stuff" on these newer engines.
Thanks.
Old Apr 17, 2011 | 06:12 PM
The PCV valve is something that you may want to change. I think that the honda brand is better quality IMO.
rrookie5
Jun 9, 2010 10:22 PM
adubu614
Aug 15, 2009 02:50 PM
live2rice
Jan 5, 2009 12:57 PM
SCEPTOR98
Oct 11, 2008 08:11 PM
jose310
Feb 3, 2008 04:31 PM
