blower not working
hey good luck, if the dash has been removed there could be so many things wrong with it. maybe a wire isnt hooked up. always go with the simple first, so check all fuses and relays
do a quick test, remove the plug that goes to the blower motor, 2 wires,,rt side under dash, make sure you got power and ground getting to blower motor,, if you get both, you got a bad blower motor if you dont, start by checking the fuses first,
Honda Man For Life
Apr 9, 2012 09:38 AM
