a/c blower not working...$1400???
Old Feb 28, 2009 | 05:03 PM
blove
Default a/c blower not working...$1400???
Took my 03 accord EX with nav/climate control to the dealer because the a/c blower will not come on. I had the problem before and changed the resistor myself for only $80. I tried this again, and it worked for less than a day. This time I took it to the dealer. They just told me that the hvac control panel needs to be replaced. It will cost over $1400 which breaks down to $645 for parts and 7 hours labor for $770. They said they need to order the two parts. (3918SDAA41ZA for $447.98 and 39172SDAA41 for $148.07) Does this sound right and how can I find a better deal? I can't find these parts online, but I think I should be able to find them cheaper and a shop to do the work for less than $770 labor. Please help. Thanks.
Old Feb 28, 2009 | 05:56 PM
Honda uses dashes in their OEM part numbers. Here are the numbers:
39183-SDA-A41ZA
39172-SDA-A41
hondapartsdeals[dot]com or majestichonda[dot]com
You can probably pick these up from a junkyard for much less money an install them yourself.
Pick up a Haynes manual for around $20 that has basic instructions to remove the center console. A shop manual has more information but is more expensive.
Old Mar 1, 2009 | 02:14 PM
blove
Thanks. I doubt I will try to tackle this myself, but doesn't 7 hours labor at the dealership seem a bit high for this job? Anyone???
Honda Man For Life
Apr 9, 2012 09:38 AM
PeteZeria
Apr 6, 2012 10:58 PM
ronjr8102
Aug 25, 2011 04:40 PM
gazz
Mar 16, 2006 11:09 AM
Green_Accord
Mar 15, 2006 08:03 PM
