Defrost,heater,AC Blower not working
Old Nov 14, 2008 | 09:52 AM
MSA
Default Defrost,heater,AC Blower not working
1994 Honda Accord.
The blower works or has been working intermediately but now hasnt worked in a few days.
Does this sound like the motor itself or just a blower motor resistor.
I understand that the blower motor (if thats what it is) is not a DIY job so I think I'll start with the resistor. Where is it located? Or is replacing the resistor a non DYI job as well.
Thanks
Old Nov 14, 2008 | 10:03 AM
hondadude's Avatar
Default RE: Defrost,heater,AC Blower not working
Usually when the resistor goes bad the fan will still run on high speed;
The 'Caveman' test can prove worn out brushes in the motor.
When the motor will not run, reach up under the glove box and smack it.
The replacement of the motor is not beyond DIY.
You can look up under the glove box to see it.
I think you have to peel back the carpet to have room to drop it out.
3 screws and one plug. GRAVY JOB [sm=happy046.gif]
Old Nov 14, 2008 | 11:02 AM
MSA
ORIGINAL: hondadude
So, if it's not blowing at all then it's most likely the blower motor.
Is that a Honda only part?
Old Nov 14, 2008 | 01:26 PM
jcocker03's Avatar
it never hurts to call your local parts stores first to see if they carry the part, thats what i always do because the dealer is usually more expensive. but with the dealer you get oem parts.
Spetsnaz2.0
Oct 19, 2019 09:16 AM
Joslinm
Oct 25, 2013 10:43 AM
Honda Man For Life
Apr 9, 2012 09:38 AM
Jonah805
Jul 26, 2011 06:08 PM
skeenr
Jan 17, 2007 11:30 PM
