Bolts for 2000 Accord Catalytic Converter
Old Mar 15, 2017 | 09:36 PM
Sled14's Avatar
Default Bolts for 2000 Accord Catalytic Converter
I'm about to swap catalytic converters on my 2000 accord 4dr ex as it is rattling.
The converter I got, a Magnaflow replacement, didn't come with replacement bolts and the ones on there look pretty rusted. I looked up replacement bolts, 3 on each end, and they run around $10 each for stock replacement ones. What would you all use? $60 for replacement bolts and nuts seems a little steep, especially when thats almost half what I paid for the converter.
Thanks for any help!
Old Mar 16, 2017 | 09:20 AM
The bolt through the converter is t-shaped wheel stud. The Honda converters have a groove in the back, so the bolt can't rotate.
If your aftermarket converter just has a hole, then I would go to a parts store and find a wheel stud that will press into the the holes in the converter. An autograde wheel bolt will work too.
jtkj
Nov 4, 2009 11:25 PM
bowisland
May 31, 2008 08:06 AM
jwshilli
Feb 14, 2008 09:45 AM
thunder_x
Jul 27, 2007 09:59 PM
Hen_Rock
Jul 12, 2007 07:34 PM
