The book states 2.2 qt for transmission oil, can I just put in 2?
Old Apr 12, 2024 | 11:07 PM
  #21
tchestman88's Avatar
Thank you! Really really appreciate it!
Old Apr 15, 2024 | 08:17 PM
  #22
Hi again! Someone told me I should a torque wrench, is this necessary?
Old Apr 15, 2024 | 08:31 PM
  #23
75Gremlin's Avatar
The torque for the two bolts should be approximately 30-33ft lb or so. You don't necessarily need a torque wrench, but I tend use one depending on the job. Many people tend to overtighten.
Old Apr 18, 2024 | 07:14 PM
  #24
Thank you!
Old May 3, 2024 | 09:16 PM
  #25
I am trying to find transmission torque specs for 2017 accord coupe 3.5L V6 Manual transmission. It seems almost impossible, been looking for about an hour and found from several sources, although not sure how accurate: fill plug is 32ft/lb, and drain is 29. Any suggestions on finding this information? You mention 30-33ft/lb, is it ok to not be 100% exact?
Old May 3, 2024 | 09:25 PM
  #26
Torque specs. for all the bolts were listed in my posts #10 images above.
Old May 4, 2024 | 08:52 AM
  #27
REDBULL, THANK YOU! As you can see, I barely know what I'm doing, really learning from scratch. After all of this, I think I'm actually good to go.
Everyone one here has been incredibly helpful. I bought the washers, got the long funnel, got the drain pan, oil, ratchet, extended bar, and torque wrench.
Watched about 5 videos on this.
I should be able to change my own transmission oil now.
Thank you!
Old May 4, 2024 | 08:59 AM
  #28
75Gremlin's Avatar
Yes, if the specs call for 29 and 32 ft lb, 30-33 for both bolts would be perfectly fine in this case. Many people overtorque their transmission or oil drain bolts to a certain extent without adverse effects. At a certain point however one can strip out the pan/bolt
Old May 5, 2024 | 10:07 AM
  #29
I understand. Thank you for the follow-up!
bladest
Jul 31, 2021 05:43 PM
AngelfromHell
Jun 1, 2010 04:37 AM
kendo
Aug 19, 2008 07:22 PM
mrmookie123
Mar 1, 2007 10:05 PM
