Sponsored by:
Sponsored by:
Brake Caliper Bolt
Old 07-15-2012, 12:30 AM
john_pyro's Avatar
Default Brake Caliper Bolt
Hi All,
Front brakes started making some noise on my '93. The pads on the passenger side were worn down to having no friction material on them. Had no trouble replacing pads on the passenger side. However, when I started on the driver side, the bottom bolt was very hard to break loose, and when I unscrewed it all the way, it wouldn't slide out of the caliper. I tried convincing it with a few taps of a hammer, it still will only come about halfway out.
Both bolts on the passenger side were easy to remove, as was the top one on the driver side. Who's got a tip to help me get the stubborn bolt out?
Old 07-15-2012, 01:24 AM
So, the thread part of the bottom bolt is fully unscrewed?
If so, try squeezing some silicone brake grease in there and work the slide pin back and forth to see if it may help it come out.
Old 07-15-2012, 10:29 AM
john_pyro's Avatar
Yes, it's fully unscrewed. I will try the grease. Thanks for the tip
theDex
10-14-2012 10:49 AM
Jet sitter
04-07-2012 07:29 PM
ennui
03-12-2010 01:22 AM
rodmathews
08-05-2007 10:49 PM
MALSR
07-24-2007 01:10 PM
Quick Reply: Brake Caliper Bolt
