Brake fluid replacement.
Old Oct 13, 2011 | 08:02 PM
RA1525's Avatar
Default Brake fluid replacement.
Hi, have a 95 Accord four cylinder, am wanting to replace the brake fluid in it. Got a quote of fifty five dollars to replace the fluid. For that price do they replace all the fluid in the lines and master cylinder which should include bleeding? Also, Honda recommends also replacing the fluid in the ABS module but nobody wants to do that, why? Advice wanted and appreciated, thank you.
Old Oct 13, 2011 | 08:14 PM
Yes, normally all the fluid in the master cylinder and lines are replaced and bleed.
The ABS fluid should normally be changed too, it is under high pressure and the bleeding procedure is separate and different than the regular brake lines. During the ABS modulator unit bleeding, the engine is started to activate the pump motor.
$50 is pretty reasonable, especially if they change the fluid in the ABS modulator unit too.
Old Oct 13, 2011 | 09:20 PM
Here's a how-to on bleeding the ABS.
https://www.hondaaccordforum.com/for...systems-31259/
93Accord2.2
Dec 17, 2021 09:59 AM
62maxx
Oct 18, 2015 08:20 AM
nyaccodguy
Mar 17, 2015 06:38 PM
JimBlake
DIY Answers.
Apr 26, 2013 01:34 PM
19962door
May 17, 2010 03:30 PM
