Brake Help NEEDED!!!
Old Sep 20, 2008 | 09:27 PM
2horsegarage
Default Brake Help NEEDED!!!
OK. I am trying to help a friend bleed his brakes in a 2000 Accord EX. We replaced all of the pads, and bleed the brakes following the procedures I have used on all my cars.....The system seems good with a nice firm pedal, butas soon as we start the car, the pedal goes to the floor with no effort. What to do?
I tried a search, and it didnt seem to be working. I am sorry if I am re-hashing an old topic.
Old Sep 20, 2008 | 10:51 PM
2horsegarage
Default RE: Brake Help NEEDED!!!
Really? Nobody has an idea? On a serious budget, and really need to be able to do this tomorrow............Thanks in advance.
Old Sep 21, 2008 | 03:10 AM
Try bleeding the brakes again to ensure all of the air is out. Check the rubber part of the lines for a bulge that would cause this problem. There is a writeup (I think) in the DIY section. The order you should do them is rearpass, reardriver, frontpass, frontdriver.
If the pedal was dropping to the floor before you replaced the pads? If so, then the master cylinder might be going bad.
rtprthd
Jan 26, 2011 06:24 PM
19962door
May 17, 2010 03:30 PM
mamtsberg
Mar 17, 2010 09:15 PM
bigsack
Apr 23, 2008 12:15 AM
98accord98
Sep 8, 2006 01:25 AM
