Brake Lighs will not disengage
(Check signature for make, model, etc.) Ive been trying to find the sencor or the brake switch. Im having a lil trouble doing so. Im wondering if my Remote start is the cause of this problem but everything looks in order...Plz Help!
Grab up your handy dandy test light; Be sure the switch plunger is pushed all the way in.
Test for power on the 'outbound' wire. Wht/Blk.
If there is power there, the switch is shorted.
REPLACE IT
REPLACE IT
Ok i found out what was wrong. I just changed the brakes and forgot to add more brake fluid. The Brake fluid was too low so the pedal wasnt high enough to reach the censor
problem solved.....
problem solved.....
the reason being,.,, that,,,, when you install new pads and squeeze the caliper piston back in,to make caliper slide over the rotor , the brake fluid level will actually rise in the reservoir ......So if it was low now, you had to be basically almost totally empty before thus the lite should have been on before ..
reason i am asking ,, is the perhaps there is a brake fluid leak in the brake system..
DannyJdm
Mar 28, 2012 08:03 AM
