Brake Light On Cluster Panel After Pressing Brake Pedal
Old May 31, 2016 | 08:54 PM
badlt's Avatar
Default Brake Light On Cluster Panel After Pressing Brake Pedal
Hello,
I have LED brake lights installed on my 2000 Accord and when I press the brake pedal, the little rear brake lights comes on in the instrument cluster and stays on. I have heard this happens because the computer thinks the rear brake light bulb is out because the LED's use much less of a load. I installed 25W resistors on the black and red wires and the light still comes on. There is also a green wire. Any ideas how to properly connect the resistors or how to make the rear brake lights stop coming on when I press the brakes?
Old Jun 1, 2016 | 03:29 PM
rockhoundrob's Avatar
Why do you need 25 watt resistors? That is HUGE, 2 or less watts is plenty.
I would think you just need 100 ohm, 1/2 watt resistor and test it out on the black wire (in line... meaning just cut the black wire and put the resistor on the black wire only).
Best way to figure out which wire is "hot" is to take the LED off and have someone press on the brakes. Check the voltage of each wire and see which one is 12 volts. Then put the resistor on that wire before it goes into the LED.
Old Jun 1, 2016 | 03:37 PM
badlt's Avatar
Hello,
That seems to be the standard. Some sell 50W resistors. The resistor needs to connect to two wires (the hot brake light and the ground).
Similar to this:
Attached Thumbnails Brake Light On Cluster Panel After Pressing Brake Pedal-f137261090.jpg
Old Jun 1, 2016 | 04:08 PM
I will have to look into it. From my electronic experience, I would have connected the resistor to the red wire only on the drawing. It wont hurt at all to use a 50 watt...
But if that is what came in the package, then go with it.
Old Jun 1, 2016 | 04:17 PM
badlt's Avatar
Yes, the only problem is that I don't have a white wire, only black, red, and green. I'm wondering if the green wire is the ground. I can't find a diagram for these wires to tell me which wire is which.
Old Jun 1, 2016 | 07:12 PM
I would guess that the white wire on the diagram is the green wire on your car, but it's not good to guess.
Best to disconnect the LED and use an ohm meter to check the green wire to your chassis ground (car). If it reads "zero" then that is "ground" for sure.
Then go one more step like I said earlier to check the voltage when someone presses on the brakes.
Old Jun 1, 2016 | 09:21 PM
badlt's Avatar
I figured it out. Not sure if this relates to all 98-02 Accords but mine is the EX model which has a small brake light failure sensor located on the driver's side under the grey material where the brake light harness is located. You need to connect the resistor to the green and black wires on both sides. Now the dashboard sensor light doesn't come on and the brake lights work perfectly. However, like other posts mention, the resistor gets super hot when in use so you need to make sure it's secured away from other wires or anything else that could catch fire or be affected by heat damage.
jjpcampbell
Jul 14, 2021 11:15 PM
victorywhity
Mar 24, 2011 09:37 PM
merz2
Dec 18, 2010 11:47 AM
atsioukl
Mar 20, 2010 10:51 AM
knownth
Oct 11, 2006 07:03 PM
