brake lights
Old May 22, 2012 | 07:50 PM
jessecolter's Avatar
Default brake lights
So this is not good, luckily gracefully i noticed none of the brake lights were coming on all of a sudden, also don't have any response from Horn or Cruise, I checked fuses, and then stuck a paperclip into two of the four connections to the brake light Switch and they came on, but replaced the Switch and still nothing.
Old May 22, 2012 | 08:53 PM
Double check the fuses, common fuse for the horn and brakes is in the under hood fuse panel....20amp #41 (according to the manaul I have).
Old May 22, 2012 | 09:00 PM
+1.
It is shown as #25 in this diagram:
1992 Honda Accord Outside Fuse Box Diagram | Auto Fuse Box Diagram
Old May 22, 2012 | 09:20 PM
Awesome yes it was that fuse, must have overlooked it. Horn and brake lights work, now just the Cruise, green light doesn't come on, checked that fuse by the pedals, hmm..
Old May 22, 2012 | 09:29 PM
Actually I must have blown that fuse when testing the original switch, drrrr.
Old May 22, 2012 | 10:08 PM
Glad you got it
Old May 22, 2012 | 10:33 PM
Well still trying to figure out the Cruise, just had it working, maybe if I bridge the wires from the push botton part on the dash it'll work telling me that's bad..
Old May 23, 2012 | 05:24 PM
Check the switch adjustment. If you messed with it (said you replaced it) then it may not be seating off all the way. Remember the brake switch has two positions, one will close off/turn off the brake light but the other is for the cruise....you can check for continuity on the wires when the pedal is not "pushed" to be sure.
rudeg
Dec 31, 2015 07:23 PM
csh217
Apr 30, 2013 09:03 PM
drive4fun
Aug 5, 2008 08:28 AM
98accord98
Sep 8, 2006 01:25 AM
