brake pedal
Old Nov 10, 2011 | 05:11 PM
lmrj0030's Avatar
Default brake pedal
I finally fixed my brake line!
It was harder than it seemed. i took out the fuel line that goes to the chambers? and squeezed my hand through to remove the other end of the pipe that connects to the proportional value i think it is.
Now, my biggest concern is that my brake pedal is so spongy.
I mean the car doesn't start braking until 3-4 inches into it.
Lets say from the top of the pedal to the very bottom is about 12"., it will start braking after 4" into it. (dont think dirty now )
I put new brake fluid and bled the brakes 3x2. so pumped each side 3x then did it again. so i pumped all wheels 6x in total.
I checked for any possible leaks but there isn't any.
What could be the cause of this?
Also if i plan to bleed again, i'm wondering if i can mix honda with toyota's DOT3 fluids
Old Nov 10, 2011 | 06:35 PM
You didn't bleed enough. It can taek 5-10 bleeds per wheel in my experience to get all the air out. Try RR-LR-RF-LF sequence of bleeding (longest to shortest).
Old Nov 10, 2011 | 07:39 PM
lmrj0030's Avatar
thanks
I was also told the same by a friend and another person from another site.
thanks again i will attempt this and post back probably saturday.
as for mixing honda with toyota dot 3. is it safe?
Old Nov 10, 2011 | 08:37 PM
enginediagnose's Avatar
I'm sure there is still air in the brake system. Keep on bleeding the system and top it off with brake fluid.
Old Nov 10, 2011 | 09:24 PM
lmrj0030's Avatar
should i bleed with the cap on or off? or it doesn't matter
Old Nov 10, 2011 | 10:36 PM
Cap on and off doesn't matter. Make sure the reservoir level doesn't go empty, or you introduce more air into the system.
I would guess that dot 3 honda and toyota are compatible.
Old Nov 12, 2011 | 02:40 PM
lmrj0030's Avatar
just wanted to update you guys that the brakes are finally stiff.
test drove the car after bleeding each wheel 6-8 times then bled them again 6-8times to get the stiffness i desired.
I went through 2 bottles in total.
Thanks for the help guys!
Old Nov 12, 2011 | 04:16 PM
Good to hear. Thanks for posting your results.
Donda
May 17, 2014 03:49 PM
Rabbit
Sep 14, 2012 02:27 PM
victorywhity
Mar 24, 2011 09:37 PM
19962door
May 17, 2010 03:30 PM
96accord
Jul 29, 2006 02:48 AM
