Brake Problems
Old Aug 10, 2006 | 09:23 PM
honker3's Avatar
Default Brake Problems
My 91 Accord EX - 118K - is having a braking problem. Basically when the brakes are applied they will grab as normal but after applying for a longer stop they will soften and the pedal will go almost to the floor with very little braking power. This seems to be worse in hotter weather while driving in town. The brakes were re-done (pads, etc about 15K ago) Any ideas what could be the problem and if so what kind of $$ to fix? Appreciate any feedback as it is getting worse.
Old Aug 10, 2006 | 09:59 PM
meazz1's Avatar
Default RE: Brake Problems
Most probably your Master cylender needs to be replaced. Make sure to buy Honda Master cylender. After market part will feel different as far as the pressure is concerned.
Old Aug 11, 2006 | 09:29 AM
mbo1985's Avatar
sounds like a master cylinder to me too.
Old Aug 11, 2006 | 12:09 PM
ORIGINAL: mbo1985
Me too.
Old Aug 11, 2006 | 03:12 PM
honker3's Avatar
Thanks for all your responses. Is this a big job? What is the cost? Will deffinitely go with Honda parts.
Old Aug 11, 2006 | 08:25 PM
mbo1985's Avatar
Well what are you comfortable with as far as mechanical projects go? If you've only changed oil you'll probably have the skills you need, you just may be challenged a bit.
In any case, get a repair manual (I keep the hanyes one in my car so I always have it. It has a special place in the trunk) and if you feel like you can do the job, go for it. It's not a big job, but these are your brakes, so you must take plenty of care and remember to do all the little things (bleed the brakes, etc.)
haven't priced the parts but I would say you won't break $200
Old Aug 12, 2006 | 03:42 AM
deserthonda's Avatar
if you go to our DIY section there is a write up on how to replace brake master .
as for the cost from Honda, it is not more than 135 dollars .
rudeg
Dec 31, 2015 07:23 PM
J2Performance
Jan 15, 2008 04:29 PM
98accord98
Sep 8, 2006 01:25 AM
KimberlyC
Apr 16, 2006 11:51 AM
