Brakes Soft When It's Hot
Old May 16, 2009 | 01:53 AM
sacramentoaccord
Default Brakes Soft When It's Hot
When it's hot my 95 Accord's brakes get soft. The best way I can describe it is when I come to a complete stop and press on the brake pedal my car stops, but as I have pressure on the pedal it continues to compress. This seems to happen when the weather is very warm, any feedback would be great.
Old May 16, 2009 | 02:32 AM
Check that the brake fluid is at the proper level. If the brake fluid is ok, then the brake master cylinder is starting to fail internally.
Old May 16, 2009 | 03:33 AM
sacramentoaccord
thank you for the advice sir.
Old May 16, 2009 | 11:49 PM
dragonle87's Avatar
could it also be the brake fluid is dirty or oxidized?
Thanks
Old May 17, 2009 | 04:44 AM
pwrhouss's Avatar
I have this exact same problem in my 95 Accord wagon. I would be interested to know what the problem is as well. I was just going to start replacing things until it was fixed, but if someone can save me some time and money, that would be nice.
Old May 18, 2009 | 07:13 AM
If the pedal sinks smoothly & slowly to the floor, as you hold the brakes at a red light; that's CLASSIC for a failing master cylinder. For some reason it's common for this to be worse as the under-hood temperatures get hotter.
Bleeding fresh fluid sometimes helps, but it's usually temporary. The only REAL fix is a new master cylinder.
Old May 18, 2009 | 09:30 AM
dfaulkner's Avatar
your master cylinder is failing. Happening on my 95 wagon too.
soba_03
Jul 19, 2010 11:12 PM
thomask
Oct 26, 2008 11:21 AM
abhijitgp
Aug 23, 2007 06:32 PM
thunder_x
Aug 6, 2007 02:46 PM
