break problems
Old Jun 6, 2008 | 01:30 PM
abelsole
Default break problems
I have a 92, and this past week its been about 95 degrees everyday. the past two days I have noticed that my brakes are really soft!!! i checked the fluid, theres no leeks. What could be the problem!?!
**I moved this to the Gen Tech Help section** - LX5spd
Old Jun 6, 2008 | 03:06 PM
nafango2's Avatar
Default RE: break problems
welcome!
the most likely problem is that moisture got into the brake system and lowered the boiling temperature of the lines. now when you step on the brakes the fluid heats up and "boils" creating gas in the lines, which is compressible.
bleed the brakes and you should be fine.
also, this should go in general tech help, this area is for suggestions and questions about this website.
Old Jun 9, 2008 | 10:46 AM
00AccordLX5spd's Avatar
Registered User
Is the pedal soft all of the time? Or does it only occasionally sink to the floor after the vehicle is already stopped?
Old Jun 9, 2008 | 06:49 PM
vtecluder617's Avatar
If the brake pedalsinks to the floor, especiallymore often in hot weather, then its most likely the Master cylinder. I have the same problem on my 94.
Old Jun 9, 2008 | 07:07 PM
deserthonda's Avatar
replace the brake master cylinder .. there is a write up on our DIY section ..
ETH13
Jan 24, 2013 09:51 AM
kamiiko19
May 4, 2010 07:24 AM
KimberlyC
Apr 16, 2006 11:51 AM
bigheadballer
Aug 27, 2005 08:16 PM
bigheadballer
