Broken AC/Heating Control Knob
Old Dec 17, 2006 | 05:17 PM
duke16
Default Broken AC/Heating Control ****
The AC and heating control *****, pictured below, have broken on my girlfriends Accord. Other they EBay and Honda, who sells them? I would really like to find some that are made a little stronger, the part that connects to the dash is just to weak and really needs to be metal, not plastic.
Old Dec 17, 2006 | 06:50 PM
hondadude's Avatar
Default RE: Broken AC/Heating Control ****
the only other option I can think of for people with the gorilla strengthto break these *****, is to buy a set of 4" vice grips, to clamp on the control shaft.
When the **** goes to the stopping point it's time to quit turning it, you can't make the A/C colder by forcing the **** past the stop point, nor will the heat be any warmer by forcing past the stop of the heat range.
Old Dec 17, 2006 | 06:53 PM
duke16
It's not a matter of turning it to far, the problem is the shaft gets stuck after not using the controls for a while. By the time enough torque is built up to turn the ****, the plastic just cracks.
Old Dec 21, 2006 | 01:35 PM
kennilope's Avatar
i had the same problem it crack at the end..
this is what I did.
put some crazy glue between the crack and the metal piece.. work like a charms....
wunderbra
Dec 29, 2010 09:30 PM
ars230
Mar 26, 2010 07:40 AM
wanted_honda
Sep 12, 2009 07:31 PM
honker3
Mar 18, 2008 11:49 AM
NALANALA
Nov 5, 2007 07:39 AM
