Broken fan switch Help
Old Feb 15, 2008 | 03:36 PM
speener
Default Broken fan switch Help
In my 2002 accord v6 the fan only works on setting three and four. 1 and 2 are somehow not working. I checked the fuses and they are good, so I proceeded to try and disassemble the dashpanel in the centre. I tried searching here and everywhere and I cannot remove this thing. I removed the clock and screws and tried prying up on the tabs that I could see, but it won't buge. Anyone have any detailed instructions or pictures on how to remove this thing. Remember that I have been searching everywhere and to know avail, the instructions i have found for stero removal (for example) are just not detailed enough.
Thanks
Old Feb 15, 2008 | 06:59 PM
Default RE: Broken fan switch Help
Switch is fine. It's the blower motor resistor pack that is at fault. Resistor pack usually on the heater module near the blower. You need a shop manual to guide your work. Tearing into the dash by guessing what needs to be removed is a recipe for damaging the trim work.
Matthew Kniss
Jun 30, 2014 06:00 PM
tomcar
Apr 1, 2014 09:00 AM
funkyguy
May 16, 2012 11:22 AM
hondaman4lifecg5
Feb 8, 2011 06:21 PM
