Bubbling sound from the steering column?
Old Sep 12, 2013 | 07:29 AM
There are a number of diy's to be found. Google "honda air mix motor". Here is one:
http://www.piloteers.org/forums/14-p...-cleaning.html
Note, your motor may not be exactly same as Honda Pilot.
Somewhere I read to use toothpicks to pry/hold the small clips till all are released and avoid breaking them.
You should examine the servo to verify it is source of noise.
regards
Old Sep 13, 2013 | 10:17 AM
briggsrepair's Avatar
Sounds identical to my issue, which the forum helped me solve.
See: https://www.hondaaccordforum.com/for...e2/#post331663
Old Feb 17, 2015 | 10:26 PM
uralswhip's Avatar
Default im under warranty should i be covered to fix the problem?
I have a 07 accord just bought from carmax. I hear that bubling sound.
Old Jan 30, 2021 | 05:37 PM
Michelle Depew's Avatar
Default Gurgling noise
Climate control or Auto Temp Control, uses a servo called air mix motor to adjust blend of heated/cooled air to achieve the selected temperature setting.
These air mix motors have a tiny potentiometer that provides feedback on servo arm position to allow precise control. W/ time the tiny wipers that track the carbon variable resistance strips create loose particles that get trapped in the grease covering the strips. This creates an alternate current path and changes resistance feedback. This results in "hunting" of the servo attempting to find a "correct" position. This sound can be clicking, rattling, gurgling sound depending on amplitude and speed of movements.
If you look on drivers side under the dash and move the temp setting, you should see the servo motor changing the blend door position. Watch for jerky random movements and for the sound you describe.
Fix is to replace or repair servo (difficult but possible).
If you think this is problem, post back and I can provide some links to repairs by others.
I have a 2003 Honda Civic that I just got and it's set for a while I need to replace the power steering pump but other than that it drives good and while I'm driving I hear water swishing behind the dash It sounds like it's in the top left part of the dash or near the steering wheel Is this similar to what you were talking about above
Old Jan 31, 2021 | 03:12 AM
I read a post where the blend doors actuator sounds like gurgling water. If you shut off the heater/climate control, do you still hear the noise?
The alternative is that you have air in your coolant and you are hearing the sound in your heater core. You can try bleeding any air from the cooling system by removing the radiator cap on a cold engine, starting the car, and turn the heat on high. This should force coolant through the heater core under your dash and removed any trapped air.
Samiken Keilholz
Jul 23, 2017 10:09 PM
Mikebike125
Sep 27, 2015 09:14 AM
Antiriad
Jul 20, 2015 07:10 PM
Rilex
Jul 19, 2013 12:41 AM
Island Accord
Feb 2, 2007 03:24 PM
