Burning Smell When Idling - '94 Accord Sedan LX
Old Jun 20, 2014 | 11:36 PM
cukaracha's Avatar
Default Burning Smell When Idling - '94 Accord Sedan LX
Hello,
I noticed recently that my '94 Accord Sedan LX (manual trans) has a burning smell that can be smelled in the cabin after driving around for awhile and then stopping. I'm not exactly sure how to describe the smell, but it's kind of a mix between oil and rubber burning.
I haven't been able to pin point where the smell is coming from, but I do drive with the windows down and the A/C off, if that's any indication of anything. I don't smell the burning smell when moving, only when the car is idling. I'm pretty sure my muffler also needs work as it is quite a bit louder than it should be.
Any suggestions as to where I should start troubleshooting?
Thanks!
Old Jun 21, 2014 | 09:02 AM
Watch your coolant level. If it's decreasing, you have a coolant leak. A cold pressure test of cooling system should ID leak. Check rear of timing belt cover for water pump drain port. Significant leakage would indicate need for a new water pump.
Watch for oil drips on cardboard piece placed under car. If oil drips, you will need to trace their location by observation of key leak sites, oil pan, rear balance shaft cover (leaks from bottom of lower timing belt cover), distributor oring where distributor meets cylinder head, valve cover seam, oil pressure switch.
Old Jun 21, 2014 | 11:32 PM
Talking T H Has The Best Answer For This. :)
I would check out what TexasHonda put in the post above.. I belive he's right on.
Old Jun 22, 2014 | 01:08 AM
MessAround's Avatar
Almost A Senior Member
Also check your exhaust system for any thing stuck to it. If a plastic bag happens to blow under the car while the exhaust is hot it could stick and melt on, then you'll smell this for a while.
Old Jun 22, 2014 | 11:13 AM
cukaracha's Avatar
Thanks for all the replies. I noticed the oil leaks, so I brought my car over to an auto shop to have them check it out. Turns out, the oil pressure sensor is shot...
Old Jun 22, 2014 | 08:30 PM
That's not very uncommon... & it drips onto the exhaust. Thanks.
pouncer11
May 16, 2012 08:43 PM
WhiteyM
Oct 21, 2011 06:28 PM
Pickrng
Jun 22, 2010 12:54 PM
MichaelT1960
Apr 11, 2008 03:03 PM
aang
May 25, 2005 07:25 PM
