A/C blows warm air and cold at same time
Old Apr 30, 2013 | 07:27 PM
Cbr1000f's Avatar
Default 2005 Accord 2.4L A/C blows warm & cold air same time
I have a 2005 Accord with 132K on the clock. Last year the field coil went bad on the A/C compressor, replaced the field coil without dis-connecting the compressor from the system. Just this week, the A/C started blowing warm air from the drivers side and cold air from the passenger side. This is NOT a dual comfort zoned system, only one temperature controller for the car! Any help would be greatly appreciated.
Last edited by Cbr1000f; Apr 30, 2013 at 07:46 PM. Reason: Did not put correct title in
Old May 1, 2013 | 02:26 AM
Sweetsasha's Avatar
Default I also have a similar problem with my AC system
I drive a Honda Accord 2006 V6. 3 weeks ago, I topped the gas a little because I thought it would make it cooler. Barely 5 minutes after, the compressor coil and clutch got burnt. I have replaced it several times and have reduced the gas changed the thermostat and eventually bought a new engine (the older one started smoking and shortening engine oil) and had a new compressor fitted. The clutch and coil burned again. I'm at a loss and all the mechanics can't seem to help. It cools for some time, like 10 to 20 minutes and then it gets burnt. I'm confused and frustrated. Please help me anyone
Old May 1, 2013 | 09:03 AM
shipo's Avatar
Am I reading this correctly; you bought a new engine because your air conditioning wasn't working properly?
Old May 2, 2013 | 06:04 PM
"CBR"- Some will call me crazy but IMO you have a low charge in the AC system. Can you, or someone, check the high and low side pressures?
Old Jun 17, 2013 | 12:32 PM
bruce960's Avatar
Default Blowing hot drivers side, cold passenger side???
I have a 2004 accord EX V-6 with the dual control system.
Last week in the heat I turned on the A/C and it blows hot on the drivers side and ice cold on the passenger side.
The dual button was on and I turned both temp controls down all the way. I also turned off the dual control and made sure the temp control was down also.
Didn't make a difference. Still blowing hot on the drivers side.
Is there a control valve that could have gone bad?
Please help as I have to take this car on a road trip tomorrow.
Thanks!
Old Jun 17, 2013 | 02:44 PM
One possibility is a low charge of refrigerant. That's one common reason for uneven cooling across the evaporator.
Another is a broken or disconnected linkage to the air-blend door at the drivers side. I never owned one with dual temperature controls, so I'm a little vague about exactly how to check that out.
Old Jun 18, 2013 | 06:01 PM
Thanks!
There is also a simple DIY way of checking for HVAC codes on these......see the sticky at the top of this section - Common DIY Threads and Info
Old Jun 19, 2013 | 07:12 PM
Cbr1000f's Avatar
After doing some more homework, I was told by Advance Auto Parts that my problem was the blend door. As a matter of fact, it was not the blend door! I found out that the system was low on freon! The evaporator is dual zoned where the passenger side gets the cold from the bottom of the evaporator and the drivers side gets it from the top of the evaporator. I put in just one can of refrigerant and the system is as cold as a well diggers backside! Problem is solved!!
Old Jun 20, 2013 | 07:22 AM
Glad you got it figured out & fixed. And THANK YOU for posting the end of the story.
Old Jun 21, 2013 | 02:46 PM
Cool.....I'm not as stupid as I thought
4x4aholic
Nov 3, 2013 06:26 AM
MHFry1
Jun 18, 2013 05:46 PM
spoconn
Aug 21, 2009 07:06 AM
dragonle87
May 6, 2009 06:42 AM
coolgmslife
Aug 17, 2007 09:43 PM
