A/C Clutch R&R separately?
Old Jun 2, 2008 | 07:28 PM
quietgiant's Avatar
Default A/C Clutch R&R separately?
My 99 4cyl vtech Accord melted the a/c clutch today.
A/C was blowing great then - 105* air. Threw clutch debris everywhere.
Question: Can the clutch be serviced without disconnecting the compressor & feon lines or, with 80k on the odom, is a new Pump & clutch in my future??
Thanks, sweating in Phx. QuietGiant
Old Jun 2, 2008 | 10:12 PM
hondadude's Avatar
Default RE: A/C Clutch R&R separately?
I'm about 99% sure it can be done; unhook the battery negative cable,[radio code?]remove the Alt. then remove the A/C compressor from it's mount. The mount itself might need be removed?
Then the lines should have enough flex to let you tilt the compressor up so you can work on the face of it.
Old Jun 3, 2008 | 08:36 AM
quietgiant's Avatar
Thanks for your help !
QuietGiant
vetski179
Feb 24, 2015 04:26 PM
clutchless
Mar 8, 2011 11:50 AM
JimBlake
May 18, 2009 09:38 PM
tamb
Jul 21, 2006 01:05 AM
Nov 4, 2005 09:54 PM
