Plugs take oil bath
Old Jun 3, 2008 | 12:13 AM
kturnerga's Avatar
Default Plugs take oil bath
Hello
My 92 Accord had its plugs changed. When I removed the cables from the plug wells some of the plug wells were filled with oil. Is this a leaky valve cover gasket?
Thanks
KT
Old Jun 3, 2008 | 12:19 AM
Default RE: Plugs take oil bath
Hope it's that. But there's ANOTHER set of seals (O-rings) further down the spark plug tubes. For THESE, you have to remove the camshaft bearing caps & all the rocker assemblies, etc.
Old Jun 3, 2008 | 10:07 AM
00AccordLX5spd's Avatar
Registered User
The valve cover gasket and upper tube seals are a fairly easy DIY and are part of "routine maintenance." here's a DIY: http://filtsai.com/accord/valve_cover_gasket/index.php
I would start there. However, if that does not fix it, you may need to replace those lower seals as JimBlake said. That is not quite as easy
otsb708
Apr 28, 2007 02:10 PM
tiberius
Oct 17, 2006 11:51 PM
St3v3
May 14, 2006 04:05 AM
LinX
Feb 27, 2006 04:01 AM
hotrod20
Dec 4, 2005 11:04 PM
