a/c compressor won't engage
Old May 15, 2005 | 01:49 PM
accordn2me
Default a/c compressor won't engage
I have a '96 that I just bought, a/c blows warm, figured it needed a charge & hooked up a can to low side- no suction at all, jumped pressure switch & fans came on but compressor does not seem to be engaging. I've checked the fuses under the hood and dash- both good. How can I tell if i've got a bad comp?
Old May 17, 2005 | 10:22 PM
Burn69's Avatar
Default RE: a/c compressor won't engage
Use a pressure tester to see if there is any leaks in it
Old May 19, 2005 | 12:00 AM
Evlampius's Avatar
ORIGINAL: accordn2me
first of all - have you read my post about the trick for 94-97 A/C cooling??
second why did you jump the pressure switch? thats not exactly how you test the compressor -
I can tell you how to check it ... please post if interested , I see that you havn't post anyother post , so I don't know if you're still interested
Old May 20, 2005 | 11:19 AM
accordn2me
I read your post about the cable, but that works fine. The problem is that the comp does not engage at all. There is refrigerant in the system still, but I can't get an accurate reading without the comp engaged. I jumped the pressure switch in an attempt to get the comp going to accept a charge. That has worked beautifully on every other vehicle I've tried it on but not this time.
If you can tell me how to test it I'd appreciate it.
Old May 24, 2005 | 08:48 PM
accordn2me
bump^
Old May 25, 2005 | 12:29 AM
Evlampius's Avatar
by the problem you describe it sounds like you need new compressor ... I have to double check something give me some time
Old May 25, 2005 | 12:18 PM
accordn2me
OK, thanks...
Old May 25, 2005 | 04:00 PM
1s
can you link me to that post because i'm considering buying a '97? thanks!
7coupe9
Nov 25, 2022 10:50 PM
tonrod
Apr 21, 2013 06:00 AM
Rice
Apr 27, 2012 08:38 AM
PitViper42
Jul 6, 2010 11:09 AM
aneelley
Apr 19, 2010 07:40 PM
