A/C Just Quit - Think It Is Electrical
Old Apr 21, 2012 | 11:01 PM
jmforde's Avatar
Default A/C Just Quit - Think It Is Electrical
1st time here. I have a '99 Accord EX V6 (235K miles) and my A/C quit today (auto-temp control system). It was working just fine until I noticed it starting to get warmer in the car as I was driving down the highway. If I adjust the temp all the way down, nothing happens - fan does not run in auto position and don't feel the compressor kicking in. I turned the fan control to manual and adjusted it up - no fan at all until I get the control to the max position, then the fan comes on full blast, but still no cooling. If I move the fan control just a little less than max, the fan shuts off - no cooling. Hitting the A/C on/off button does nothing except change the display.
I am guessing the fan control switch is bad and that somehow keeps the A/C compressor from coming on, but these are uncharted waters for me. I have fixed most other things on this car, but never worked on the A/C. If anyone has any input on how to correct this, I would be most appreciative.
Mike
Old Apr 22, 2012 | 05:58 AM
Is this a infinitely-variable speed fan, or incremental speed position fan. Some w/ I-V speed, have a power transistor that modulates the voltage to the fan that will go out. I've had to replace this piece (plug in componentO on my 03 Acura MDX and I know it's used on other Honda/Acura products.
If you feel comfortable w/ electrical problems, I would recommend getting a Honda shop manual for car. Check Online Manuals post in DIY forum for a free download, or go to ebay seller "automanualsource" for a $21.99 download manual. This will schematics and diagnostic procedures to trace your problem.
Old Apr 23, 2012 | 07:25 AM
jmforde's Avatar
Is this a infinitely-variable speed fan, or incremental speed position fan....
Yes, it is an I-V type. A co-worker was saying the same about replacing a resistor. His was in a compartment on the fan motor. Would that be the same on the Honda Or would it be on the switch in the dash?
Thanks for your help!
Old Apr 23, 2012 | 06:37 PM
Again, I would try to get the codes. For the auto HVAC try this
Attached Thumbnails A/C Just Quit - Think It Is Electrical-6th-gen-hvac-auto-dtc.jpg
Old Apr 23, 2012 | 10:48 PM
jmforde's Avatar
This is interesting. Thank you so much - didn't know there was such a self-diagnostic built into it. After reading the instructions, I did a search for the codes corresponding to each of the segments, and have yet to locate them. Would you possibly have a link to the code definitions?
Thanks, again, to all that have replied. Once I actually fix this, will post my findings.
Old Apr 24, 2012 | 06:56 PM
Prob still going to be something in the blower system but here you go
Attached Thumbnails A/C Just Quit - Think It Is Electrical-6th-gen-hvac-auto-dtc-codes.jpg
Old Apr 24, 2012 | 07:56 PM
jmforde's Avatar
Thank you so much! Won't be able to do anything now until this weekend, but will let you know how it goes. Thanks, again!
Old May 11, 2012 | 05:55 PM
jmforde's Avatar
Default Fixed!
I FINALLY had time to work on my accord today. Ran the climate control self diagnostics with result "N", a problem in the blower motor circuit. Pulled the blower motor resistor, put an ohm meter across the contacts in all possible combinations, and had an open circuit on all. Called around and found, to my surprise, that not only was the honda dealership the only one with the resistor in stock, but they were less expensive than the other parts stores by as much as $25! (dealer price was $56.33 + tax) Put the new one in, and the system works like new!
Thanks again to everyone for their input!
Tony1M
Nov 6, 2023 08:29 PM
leaded
Sep 7, 2008 09:05 PM
graydw1
Sep 13, 2007 11:26 AM
fuctcivic
Nov 17, 2006 03:34 AM
YeuEmMaiMai
Aug 3, 2006 03:02 AM
