Can I keep my 4cyl brake calipers?
Old Oct 14, 2013 | 09:45 AM
JonJon13926's Avatar
Default Can I keep my 4cyl brake calipers?
I'm doing the five lug swap on my car in order to fit 2010 accord wheels on. I'm doing the front first. I have calipers on the front, so all I needed to do was swap knuckles (which I have), calipers (which I have), and obviously rotors. I also opted for changing the outer tie rod ends while I'm at it.
I haven't started on the front end swap out yet because I've still got to go over to a friend's house and use his press to put in lower ball joints on the new knuckles, but I went ahead and put the v6 calipers on my car the other day to get that part out of the way. (I got them from a junkyard, but I was fairly certain they would be fine). Well they weren't. I bled the system way more than necessary and there was definitely no air in the system, but I had no brakes still. I put the 4cyl calipers back on and bled a few times and my braking power returned back to (or better than) normal. So I started thinking, obviously the 4cyl calipers will bolt to the v6 knuckle, so why do I even need to switch the calipers out?
Old Oct 14, 2013 | 12:44 PM
The only reason I can think of, is if the V6 rotors are a larger diameter.
Old Oct 14, 2013 | 08:07 PM
The v6 rotors might be a little bit larger, I'm not entirely sure. But probably not by a lot because the v6 calipers physically fit onto my 4cyl rotors just as well as the 4 cyl ones did. The caliper piston and the pads are a tad bigger, but that's about it.
Old Oct 15, 2013 | 07:02 AM
If the piston is larger, that will affect front/rear brake balance. Bigger pistons = more clamping force in front. Probably because of more weight in the front of the car. I'd say the 4-cyl calipers are OK temporary until you find V6 calipers.
Old Oct 15, 2013 | 07:07 AM
Yeah that's what I thought. The v6 is heavier and therefore requires more force to slow it down. But since mine is a 4cyl and will stay a 4cyl I probably wont need the larger calipers.
And as far as I know the rears are the same on the 4cyl and the v6. Or so I've read.
Old Oct 15, 2013 | 07:19 AM
Oh that's right, I wasn't thinking about your car still being 4-cyl... (Where's that hammer-head smiley?)
Old Oct 15, 2013 | 01:16 PM
hondafreak91c's Avatar
Since your car is a 4-cylinder, you will be fine. Personally though, since you have everything apart, you might as well upgrade the brakes.
letsclique
Jun 9, 2012 10:08 PM
crshbandit
May 18, 2011 08:21 PM
L7oser
Jul 13, 2009 10:58 AM
LSStrongman
May 16, 2008 09:13 AM
nmikmik
Nov 21, 2007 08:04 AM
