Can someone help me diagnose my problem?
Old Apr 1, 2012 | 09:43 AM
jlumptx's Avatar
Default Can someone help me diagnose my problem?
Please forgive me for sounding like a moron because I know next to nothing about cars or car repair, but my 98 Accord is broken and I also have next to no money and need to figure out what the problem is so I can try to fix it or get my dad to help me fix it.
It started about 2 weeks ago, occasionally I would get resistance from the gas pedal when trying to drive immediately after starting my car. This only happened once, but almost every time I started the car. After the initial press, the pedal operated normally. Then in a couple days I noticed some light smoke or steam coming from my center two AC units. This only happened once, so I chalked it up to high humidity. Then my car started dying after I started it, but usually if i just gave it some gas right after I turned it on I could keep it going and then it would drive fine. Then yesterday I was driving home from work and my girlfriend noticed there was a similar light smoke/steam coming from my steering column near the instrument panel. Next time I tried to drive it I could not get it to start at all.
I'm not sure if all of these problems are related, but I really need to figure out how to get it running again. Thanks for your help!
Old Apr 1, 2012 | 10:08 AM
kyle102565's Avatar
stop driving it and get it to a shop. smoke means fire. if youre in a high humidity climate the steam is merely steam. does it smell like smoke?
Old Apr 1, 2012 | 10:14 AM
jlumptx's Avatar
It has a chemically smell to it, not really like smoke. I think it is steam. I opened the hood immediately after driving and there was no sign of smoke or overheating at all.
Old Apr 1, 2012 | 10:43 AM
When you say that you could not get it to start at all, what is happening exactly?
Old Apr 1, 2012 | 10:47 AM
Have a test light or volt meter? Check for voltage on the BLK/YEL wire into the dist.....sounds like the elect part of the key switch went up in smoke.
Old Apr 1, 2012 | 10:52 AM
jlumptx's Avatar
It turns over like it wants to start, but won't catch.
Old Apr 1, 2012 | 10:59 AM
jlumptx's Avatar
I have no idea what you just said to me, but I don't have any of those things.
Would it still attempt to turn over if this was the case?
neldee
Apr 27, 2013 11:54 AM
sir_nasty
Feb 7, 2007 04:19 PM
Sparco_racingVTEC
Jul 26, 2006 09:11 PM
98Accord220HP
Jul 23, 2006 05:29 PM
