Can you flush ATF through the cooler lines?
Old Sep 10, 2013 | 04:23 PM
jkowtko's Avatar
Almost A Senior Member
ok, then that's 40% new fluid per drain-and-fill, and a compounded total of 78% for three. So using 8 qts of new fluid you are still leaving over 20% old fluid in the system.
In comparison, a drain-and-fill followed by a cooling line flush should give you 90-95%+ new fluid using the same 8 qts.
Old Sep 10, 2013 | 04:41 PM
For the flushing procedure, you should purge the disconected line (air pressure or oral pressure) to the reservoir, before draining the reservoir of old fluid. This will allow draining of old fluid trapped in ATF cooling lines.
For the very **** retentive, the procedure in the youtube videos used an intermediate flushing w/ Type IV ATF, before introducing the Honda ATF.
Old Sep 10, 2013 | 05:01 PM
jkowtko's Avatar
That video also blows out the old fluid from the cooling line AFTER refilling the reservoir!
Old Sep 10, 2013 | 07:32 PM
OK sorry. I thought the predominant mixing point was at the torque converter. Guess those connections aren't as restrictive as I assumed.
TXAccord2012
Dec 10, 2012 12:17 PM
OLDERTUNER94
Aug 13, 2012 06:30 PM
moey
May 22, 2011 10:43 AM
Big Tex
Sep 8, 2008 09:42 AM
DoctorSub
Aug 3, 2006 09:40 PM
