cant find proper procedure to clean egr passages on v6
Old Nov 18, 2010 | 02:03 PM
embpilot's Avatar
Default cant find proper procedure to clean egr passages on v6
hi folks,
I got a 3.0L 2004 accord that is displaying the symptoms of clogged egr passages. (hesitating under load etc...) My problem is I can't find the proper procedure to do this on a 2004 3.0L. Can anyone here shed some light on this???? I've looked on this forum and others but because I'm not too computer savvy Ive come up with zilch....Thanks in advance guys.
Old Nov 18, 2010 | 02:51 PM
This is the pdf for 98-02 V6 accords.
tegger.com/hondafaq/tsb/accord/A99-085.pdf
The manifold for your 04 accord in the picture below should have a similar setup. The hole in the gasket below #8 should be for the EGR port.
Old Nov 18, 2010 | 04:03 PM
embpilot's Avatar
Default re
thanks for that. I think its not quite compatible with my vehicle though. Let me ask you this. Is R/R ing the manifold much more than just removing the bolts and lifting it off? It doesnt seem all that complicated.
Old Nov 18, 2010 | 04:06 PM
What is R/R ing?
Old Nov 18, 2010 | 04:28 PM
All you need to do is remove the intake manifold upper cover.
Remove the intake manifold upper cover (#4) and clean the intake manifold EGR port with carburetor cleaner and a brush.
The upper cover mounting bolts and nuts should be removed sequentially. After cleaning, install a new gasket (#6) and tighten the bolts and nuts sequentially. (Torque: 8.7 lbf-ft.)
Attached Thumbnails cant find proper procedure to clean egr passages on v6-upper-manifold-cover.jpg
Old Nov 18, 2010 | 05:41 PM
embpilot's Avatar
Default re
R/R -remove and replace, sorry for the lingo.
OK, ill try removing that upper plate and giving it a good scrubbing. thanks
Old Nov 18, 2010 | 06:04 PM
embpilot's Avatar
Default re
ok, i did the cleaning as you mentioned but i noticed what looked to be as an abnormal amount of oil in the cavities. is this normal? ill let u know how it rides in a few mins
Old Nov 20, 2010 | 07:36 PM
Oil inside the intake manifold? That might be a clogged PCV valve. How about oily stuff in the throttlebody?
Old Nov 26, 2010 | 08:54 AM
embpilot's Avatar
Default re
no oil in the throttle body but the plenum is pretty oily. I guess ill try thr PCV valve. Any other suggesstions? Is the only EGR [ort just on the top side of the engine??? or does the plenum need to come off? thanks
Old Nov 26, 2010 | 11:07 AM
Generally, the plenum does not need to come off and do any additional cleaning. Are you experiencing drivability problems or get a trouble code?
Changing the PCV valve is always good.
gigem891
Jun 29, 2013 02:09 PM
anim8onme
May 12, 2013 07:40 PM
the cyclops
Jul 24, 2011 03:05 PM
dakwag
May 19, 2011 04:40 PM
Anse
Jun 6, 2009 05:09 PM
