Can't pull off snorkel tube...
Old Jun 20, 2011 | 02:10 AM
MessAround's Avatar
Almost A Senior Member
Default Can't pull off snorkel tube...
On a 1993 Honda Accord (4-cyl 2.2l) I'm trying to remove the snorkel tube so I can clean the throttle body. I can remove the snorkel tube where it meets the air filter box but where it meets the throttle body is a nightmare!
There are all sorts of rusted pipes hanging off of the snorkel tube and I can get a few off but I'm afraid to break one. They're stiff. Then there's the one giving me the most problem. It's the thin pipe sticking out right where the throttle body meets the snorkel tube. It sticks out toward the sky and makes a right angle towards the drivers side.
I tried pulling on it and twisting on it but it wouldn't budge. I'm not sure if it's just old or if it's not meant to be pulled/twisted. I don't see how I can pull the vacuum tube without doing this. I'm trying to find a picture to show this...
It goes into the little thing that looks like the FITV but it's not the FITV, it's the thing closer to the brake master cylinder.
Old Jun 20, 2011 | 03:13 AM
Try using PB Blaster or WD-40 to help get those items off.
Not so familiar with the 93, but usually hoses and such have a metal clip that keeps those items secured, so they don't fall off.
Old Jun 20, 2011 | 06:47 AM
MessAround's Avatar
None of the service manuals appear to mention this thing.
It's held on simply by being plugged on. It's not held on by a clamp or anything if that's what you're talking about.
I can see some rust on the base where the bottom of the tubing meets the snorkel tube.
Old Jun 20, 2011 | 07:38 PM
Pic's??? Might help, I like PA am not that good with the 4th gens....however a pic or two might do the trick.....on the 3rd and 5th gen's there is a clamp right at the TB.
Old Jun 20, 2011 | 08:35 PM
MessAround's Avatar
I'm trying to get one.
The clamp is at the TB. That's not the problem, the clamp is easy to pull off It's just that on the tube itself is a little jut where a little pipe sticks in and that pipe isn't coming out. There's no clamp on that pipe like there are for tubes like the coolant tubes so I don't even know if I'm allowed to pull this thing out. I tried pulling and twisting on it and it wouldn't budge.
Even if I were to remove the clamp, since this offending pipe is attached to the tube and this pipe is anchored and can't stretch I would be unable to pull the snorkel tube out and move it out of the way so I can access the TB.
I looked in the Hanyes manual and it appears to be the Startup Valve that this pipe is connected to. The Startup Valve looks similar to the FITV and it's right next to it. Only the FITV and IACV are on the same side and face the fender but the Startup Valve is on the adjacent side facing the brake master cylinder and the drivers side.
Old Jun 20, 2011 | 08:55 PM
In the attached image, are you referring to #28?
Old Jun 20, 2011 | 09:01 PM
I don't know if these instructions and pictures in this link will help you:
lightningmotorsports.info/90accord_cai_install.htm
Of course you don't need to remove everything that's shown in the link, as you are not replacing it with a cold air intake.
Old Jun 20, 2011 | 09:08 PM
MessAround's Avatar
Excellent picture. You see number 32? To the left there's that little pipe floating? To the left of it you see the little jut sticking out? That's the thing the pipe goes in to.
Here it is.
http://www.lightningmotorsports.info.../90Accord9.jpg
It appears to be the "vacuum line on the nipple."
I guess I'm supposed to pull on it?
Old Jun 20, 2011 | 10:19 PM
Tek310's Avatar
i dont understand? it looks to be off?
vetski179
Apr 13, 2015 02:27 AM
DisplacedMic
Mar 25, 2011 07:17 AM
czhonda
Mar 4, 2010 08:10 AM
mck52689
Jul 17, 2007 03:40 PM
cj_trap_shooter
Mar 22, 2007 02:58 PM
