Sponsored by:
Sponsored by:
Car does not starts sometime...
Old 08-31-2015, 04:01 PM
inayat.malek's Avatar
Default Car does not starts sometime...
I have 07' accord - V6, car does not start sometime (No crank) but if i move shifter from park to other position and move back to park, it starts immediately....this happens once in a 2-3 days....
Any idea what could be the issue, i have new battery and car starts normally manytimes only few time it does not start, no crank....
is it Neutral safety switch??
Old 08-31-2015, 07:55 PM
You need to be clear about problem. Does car refuse to turn over when no-start arises, or turns over but does not catch/run.
The transmission range switch inhibits start unless closed (P or N). If starter does not turn over at all, this may be problem. It is external to the trans and can be replaced.
Old 09-01-2015, 08:02 AM
Thank you for your reply, car start normally each time when no start arises...
issue is - car does not start at first (with no start no crank - start and run normally if shifter moved from P to other position and back to P)...
Old 09-01-2015, 08:45 AM
I'm going with "starter turns engine over but no engine run".
There are several possibilities:
1) Ignition switch intermittent fault leading to no start signal. Possibile but unlikely.
2) Starter cut relay (under dash fuse box) is intermittent.
3) Intermittent starter solenoid causing fault.
4) Transmission range switch faulty.
Suggest inspecting for start signal (12V) on blk/wht wire at starter to confirm start signal is missing when no-start is present. If yes, check for ground signal at the starter cut relay Light Green wire. If missing w/ trans in P or N, the trans range switch fault is confirmed.
Old 09-01-2015, 09:21 AM
Thank you for your reply.
shook
01-26-2012 02:52 PM
kamofly
12-03-2011 07:02 AM
POS-Accord92
11-07-2011 06:50 PM
ThangxTroixDanh
05-28-2009 09:10 AM
kuvasz
05-03-2007 12:33 AM
Quick Reply: Car does not starts sometime...
