Can anyone help please? Shaking issue
Old Aug 21, 2015 | 11:45 AM
Kaimeng9's Avatar
Default Can anyone help please? Shaking issue
I bought an 07 v6 accord back in april, everything as fine then.
Recently I started to feel that the car shakes gently but noticeably through the seat when I accelerate through 20 mph. It goes away when I reach higher speeds. The steering wheel doesn't shake or vibrate, and there's no noise when the car shakes. Front two tires are 5 months old and rear two tires are brand new.
What are the probable root cause?
Thanks.
Old Aug 21, 2015 | 12:35 PM
shipo's Avatar
Three possibilities:
  1. Bent wheel
  2. Bent axle
  3. Failing CV joint in axle
Old Aug 21, 2015 | 02:43 PM
Turtlehead's Avatar
Also
Tire is out of round
Motor mount (hydraulic style) failing
Old Aug 21, 2015 | 03:37 PM
Swap your wheels around to see whether it feels like it moved to a different corner.
Old Sep 1, 2015 | 09:06 AM
Kaimeng9's Avatar
  1. Bent wheel
  2. Bent axle
I actually went to a shop and had those checked out. Those parts are In great condition.
A friend pointed out it might be the transmission's problem. Honestly that's what I guessed to be the cause at the first place.
Old Sep 1, 2015 | 09:08 AM
Kaimeng9's Avatar
  1. Bent wheel
  2. Bent axle
But the transmission is not giving any malfunction code. I read cases of people encountering the same problem, and there're two that replaced the transmission and fixed the problem.
Old Sep 1, 2015 | 09:27 AM
shipo's Avatar
I highly doubt changing the transmission will eliminate a shaking issue.
Old Sep 1, 2015 | 09:40 AM
Kaimeng9's Avatar
So if it's not anything bent, nor cv joints and engine mounts, what's your next best suspect?
Old Sep 1, 2015 | 12:34 PM
shipo's Avatar
Axles.
jfreakofkorn
Dec 7, 2013 08:33 PM
Hebby73
Jan 10, 2012 03:23 AM
david1212r
Aug 15, 2011 12:53 PM
art vandelay
Aug 2, 2010 09:29 AM
chalee82
May 17, 2006 12:44 PM
