Car would not start. Hood couldn't be opened. What can I do?
So I left my car (2002 Accord 2.3L SE) unused for about a week under freezing weather. Now it won't start. The battery is about 5 years old fyi.
I couldn't open the hood because of the previous accident (previous thread)
There is a small gap between the hood and the body. Not sure if the jumper cable can reach the battery
(Img1, Img2)
Is there any way to fix this? Thank you!
(Img1, Img2)
Your battery is on the driver side. You are going to have to find someone to get the hood open for you. If you have another person to assist maybe someone can pull the lever as the other pull up on the hood if it still works
Originally Posted by undergrad007
Thank you. I believe the battery is on the passenger side (link). Unfortunately open the hood is not an option because it won't be able to close again
The only suggestion I can give is if you want to get the car running you are going to have to open it up or bend the hood (not suggested). If you get it open and need it to be closed get rope and tie it down. Those are your only options unless you get the damage fixed.
cpalmer3769
Jun 7, 2016 09:03 PM
Turkey Shampoo
Oct 26, 2009 09:04 AM
