2008 Honda Accord v6. ABS/ VSA lights
Old Dec 15, 2018 | 08:55 PM
Raider103's Avatar
Default 2008 Honda Accord v6. ABS/ VSA lights
Both the VSA and ABS lights have been on for months. Don’t remember when they turned on, haven’t noticed anything weird while driving. Code 66-1 came up but I’m getting mixed info on what that is. Any info/tip would be helpful. Is this fixable at home or should I let the dealership handle it?
Old Dec 15, 2018 | 10:28 PM
VSA & ABS both use the wheel-speed sensors. I don't have the error-code list, but if that code is for a wheel sensor that would explain both.
IF its a sensor there's a few things you can do.
- Look for wiring problems like cut or pinched wires from the sensor
- If you can take apart brakes/hubs, check the sensor itself for magnetic crud buildup on the sensor.
- Measure electrical resistance vs. a value that it should be (anyone have a 2008 shop manual?)
Old Dec 16, 2018 | 05:53 PM
The Toecutter's Avatar
And if it's anything like my daughter in laws 08 Pilot, she takes it to the dealer to clear the code, as they haven't found out why it turns on the lights, as there's no codes found.
reyj1727
Nov 18, 2016 12:38 PM
aggver
Dec 25, 2015 10:43 AM
mrfoo
Nov 20, 2012 08:25 PM
Accord2008
Oct 12, 2007 07:56 PM
Cheif
Jul 15, 2006 11:22 AM
