Catalytic Converter replace?
Old Jul 14, 2023 | 09:55 AM
btartus's Avatar
Default Catalytic Converter replace?
1995 Honda Accord LX 2.7L
is it recommended on such an old car to put a new CAT? pros? cons? and if its recommended, without breaking the bank, what brand of CAT is recommended?
I currently have a Vibrant muffler on the car which sounds great, and the rest of the exhaust is all original.
thanks folks!
bt
Old Jul 14, 2023 | 01:30 PM
The 95 accord was OBD2, so it should have a secondary O2 sensor monitoring the catalytic converter performance. If you are not getting a P0420 code or loss of power with a clogged catalytic converter or a rusted hole through the converter, then don't replace. The OEM Honda converters are better quality than aftermarket IMHO.
Old Jul 14, 2023 | 02:29 PM
btartus's Avatar
thanks very much!
Old Jul 15, 2023 | 06:44 AM
btartus's Avatar
Originally Posted by btartus
thanks very much!
if you were to put an aftermarket converter on a 1995 Honda what brands are recommended. I cant imagine how expensive an OEM Honda Cat Converter is, if its even available. I am finding more and more parts discontinued for this car.
its it safe to assume after 28 years its a good idea to put a new Cat on the car, is it safe to assume it must be clogged and corroded after 28 years, especially from the Florida heat its entire life,
Old Jul 16, 2023 | 09:38 AM
I never had to replace a catalytic converter on my accords. It isn't safe to assume the converter is clogged after 28 years, because you'd know if you were driving on a clogged converter. The corrosion I mentioned was more on the outside where you'd eventually have a rust hole. This might happen in the north with the salt on the roads, but would also be rare. Don't replace the converter unless you start getting something like a P0420 code or severe power loss due to a clogged converter.
Old Jul 16, 2023 | 12:06 PM
btartus's Avatar
ok got it! thanks so much! great advice!
HondaLawgik
Feb 24, 2011 12:14 AM
blackex19
Aug 22, 2007 02:37 PM
Hen_Rock
Jul 12, 2007 07:34 PM
Sparco_racingVTEC
Aug 16, 2006 12:20 AM
#1hondaaccord
Oct 3, 2005 09:31 AM
