Center Console removal
Old Nov 1, 2006 | 11:08 PM
MALSR's Avatar
Default Center Console removal
I've got a really bad dash-rattle coming from underneath the shift-selector (automatic transmission). Sounds like a loose screw is just rattling around in there. My question is how do you pull out the cover that goes around/underneath the shifter. Do you have to disassemble the shifter ****? or can you pull it off some other way?
Old Nov 2, 2006 | 04:16 AM
Default RE: Center Console removal
This job isn't too bad. You'll have to remove the ****. I would suggest buying a Haynes manual. It will give you enoug information to guide you through the job.
Old Nov 2, 2006 | 11:49 AM
deserthonda's Avatar
do not remove the shifter ****,,,,,,,you got to remove the center console
there are screws on each side of the console , also inside the console , there is a cover, you need to pop it out with a small screwdriver, there are screws under that cover
rah140
Nov 7, 2010 11:59 AM
maro
Apr 6, 2007 11:40 AM
tubbybrown
Nov 16, 2006 02:36 PM
johnc
Mar 6, 2006 05:14 PM
itsmetinh
Jan 1, 2006 11:42 PM
