Chain Case Cover over Timing Belt Tensioner
Old Jul 6, 2009 | 12:12 PM
JohnAccord2007
Default Chain Case Cover over Timing Belt Tensioner
Hello, Just curious if anyone know: In 4cyl Honda Accord, why does the timing belt tensioner have the separate cover over it? I know this allows the tensioner to be replaced easier (without removing the whole chain case) but
1. Does the tensioner really have to be replaced so often that this is necessary? (I would think it could just be checked/replaced when the timing belt was replaced).
2. It doesn't look like it is possible to inspect the timing belt through this cover, right?
3. It doesn't look like the tensioner can even be checked through this window (since the extension of the tensioner arm cannot be measured from this window), right? So how would you know if the tensioner was bad through this cover anyway?
Thanks for any responses!
John
Old Jul 6, 2009 | 12:45 PM
Just checking... You're talking about a 2007 (judging from your screen-name)?
It has a timing chain, not a belt.
You check wear on the chain based on how far the tensioner is extended (13.5mm maximum). I don't remember the details of how you measure it...
Old Jul 6, 2009 | 05:13 PM
JohnAccord2007
Default Yes, 2007!
Yes, Sorry, I am asking about a 2007. Thanks for the info. Just curious why the tensioner has its own cover -- especially since it looks like the tensioner extension measurement (the 13.5mm) can't be made w/o removing the entire engine front cover...
Thanks again!
John
Old Aug 12, 2012 | 09:22 PM
mhonda49's Avatar
anybody know how to take timng chan cover off on 2003 honda accord. all visible bolts taken off already. should it beable to just pop off
Old Aug 13, 2012 | 08:35 AM
Dr. Drivability's Avatar
here ya go...
ss485
Feb 23, 2011 08:18 PM
DisplacedMic
Jan 25, 2011 08:51 PM
tradosaurus
May 7, 2007 01:08 AM
olorin
Jan 22, 2007 05:22 PM
