Changing Brake pads in a 98
Old Aug 21, 2006 | 05:15 PM
jrcastro's Avatar
Default Changing Brake pads in a 98
Getting to follow the DIY write up for changing pads. Had a few questions before diving in:
Is it easy?
Can I use ceramic pads?
Signs on getting rotors resurfaced?
Do i need to bleed the fluid?
thanks in advance
Old Aug 21, 2006 | 06:54 PM
deserthonda's Avatar
Default RE: Changing Brake pads in a 98
ORIGINAL: jrcastro
Is it easy?
thanks in advance
A : very easy
B : you can if you want,, i rather stick with HONDA PADS
C : if steering wheel shakes while driving, deep grooves,
D : no need to bleed brakes
if you follow the directions on our DIY section you will be just fine
PackManDan
Jul 20, 2015 11:11 AM
dragonle87
Feb 11, 2009 10:28 PM
62maxx
Dec 12, 2007 03:14 PM
ssc280
Apr 27, 2007 10:13 PM
