Check engine on
Old Dec 31, 2007 | 09:42 AM
yanxuhec's Avatar
Default Check engine on
99 Accord 4dr Lx standard, couple days ago forgot to turn off my lights, the battery went dead reboosted the next day but
-Check engine light went on
-Remote starter won't start
but I can still use the remote door lock and start the car with my key
should I change the battery??
Old Dec 31, 2007 | 10:33 AM
Default RE: Check engine on
Have battery load tested and check the DTC at Autozone. If battery checks OK, reset the ECU and see if code returns.
Old Dec 31, 2007 | 10:34 AM
JohnL's Avatar
God knows! Did you "reboost" without disconnecting at least one battery terminal?
Old Dec 31, 2007 | 03:19 PM
yanxuhec's Avatar
battery fine, did a Ecu so far so good ( check engine went off and stay off)
but remote starter still no working
tks
Old Dec 31, 2007 | 07:12 PM
Chiovnidca's Avatar
ORIGINAL: yanxuhec
tks
What brand is it?
Old Dec 31, 2007 | 10:59 PM
HondatechAV6's Avatar
you might have to relearn the remote start.
RA1525
Apr 15, 2012 07:50 AM
blahblah
Mar 18, 2007 02:33 PM
hopkinted
Dec 30, 2006 04:41 PM
99 EX V6
Mar 3, 2005 03:42 PM
