check engine light
Old May 9, 2012 | 08:41 PM
zack's Avatar
Default check engine light
I have a 07 accord. my check engine light keeps coming on, when i put it on the computer it gives me a code P2138. I've been told it is the app sensor. Does any one know what to do?
Old May 9, 2012 | 09:01 PM
crispin's Avatar
change your throttle position sensor.
Old May 9, 2012 | 09:34 PM
Yes, it may be the Accelerator Pedal Position (APP) Sensor
As the accelerator pedal position changes, the sensor varies the signal voltage to the ECM/PCM. Check the connector first.
See this thread for a diagram showing location of the APP sensor on a V6. I believe for a 2007 Accord, the location is similar for 4 and 6 cylinders.
https://www.hondaaccordforum.com/for...-issues-37602/
Old May 9, 2012 | 09:39 PM
What trim level is yours (LX, EX, etc.) and how many cylinders?
Old May 9, 2012 | 09:59 PM
The APP sensor is Honda part number 37971-RCA-A01. It looks like its the same part for 4 and 6 cylinders for 2007 Accords.
2006 - 2007 4 cylinder Accords had drive-by-wire and Honda included the APP sensor.
2003 - 2007 V6 Accords had drive-by-wire and the APP sensor.
Earlier 7th generation Accords 4 cylinders (2003 - 2005) didn't have drive-by-wire and didn't appear to have the APP sensor.
Mott
Mar 15, 2016 11:25 AM
ddold@gkschools.org
Jan 29, 2008 03:35 PM
hotrod01
Nov 11, 2005 01:28 AM
