Check Engine Light Issue
Old Sep 12, 2012 | 10:44 AM
Originally Posted by Mer1
I recently had this problem with my 94 accord vtec and got the check engine light to reset by reseting the maintenance button (using the car key) on the dashboard. Pulling the fuses didn't work but the dashboard reset did! Give it a try if you are still having this problem.
Probably just a coincidence for your 94 Accord. The maintenance indicator on the 94 is just a mechanical counter with gears based on mileage that is part of the speedometer/odometer head. It has nothing to do with any sensor or the ECU. Attached is a picture of the back of the unit.
Attached Thumbnails Check Engine Light Issue-maintenance-required-indicator.jpg
ddold@gkschools.org
Jan 29, 2008 03:35 PM
megaman
Sep 16, 2007 01:46 AM
hotrod01
Nov 11, 2005 01:28 AM
