"Check Gas Cap"
Old Dec 11, 2015 | 07:23 PM
Corvair's Avatar
Default "Check Gas Cap"
I just got a message that says "check gas cap" on the center of my dash. I checked it twice. Removed and inspected it. Still came on. Car is a '14, 4 cylinder, manual, 42,000 miles. It has about a half tank of gas. Weather is in the low 30's. Warm for this time of year.
What I did was put a little spray on grease around the gasket on the gas cap. Put it back on. Message did not reappear.
Is this a long term fix, or did I do something I shouldn't have done? Can I assume it's the gas cap gasket? Authorized Honda dealer is 45 miles away.
Thanks
Old Dec 11, 2015 | 08:12 PM
After every fuel fill-up. just tightened the fuel cap at least 3 clicks. If you tighten it at least 3 clicks, you should not have the issue anymore; unless the gasket was bad.
Old Dec 11, 2015 | 08:48 PM
Corvair's Avatar
I only go one click.
Old Dec 11, 2015 | 09:00 PM
The 3-clicks (at least) is part of published Honda info. to techs/advisers.
Old Dec 11, 2015 | 09:09 PM
Corvair's Avatar
Thanks, I'm used to my ex Fiesta, where it would have some hard to find vacuum leak that would take the dealer three trips to find.
Old Oct 15, 2019 | 12:24 PM
pspens's Avatar
Smile
Glad I found this. I have a 2013 Honda and just got a "tighten fuel cap" message for the first time today. I filled up last week, so I wondered what was going on. I tightened the fuel cap 1 click but warning remained. After reading this, I did 3 clicks and warning went away. Wow! In the past I've been doing only 1 or 2 clicks.
Old Oct 15, 2019 | 03:24 PM
Check the gasket on the cap & also the rim of the filler pipe where the gasket seats.
The car is really measuring whether the fuel tank is airtight like it should be, and there's a bunch of other possibilities like the fill pipe connection to the tank, or the gasket around the fuel pump flange. If it continues, then you're in for an adventure of checking all kinds of rubber hoses & stuff.
Old Oct 15, 2019 | 04:34 PM
pspens's Avatar
Well, as I said, the problem went away after tightening 3 clicks. I was vaguely aware that I might have been in for some heartburn had it not. A punctured filler pipe came to mind, but I didn't remember any trauma.
Reggi's-accord
Jun 6, 2012 07:17 PM
LS-300
Mar 3, 2012 08:33 AM
HondaAficionado
Nov 30, 2010 05:24 PM
Fat Ryan
Apr 16, 2010 09:50 PM
jackkpts
Aug 28, 2009 03:32 PM
