Chipped ecu problems
Old Dec 1, 2020 | 01:21 AM
Sdalton's Avatar
Default Chipped ecu problems
I just bought an obd1 p28 chipped ecu that was tuned by a guy in California, I’m in Missouri. I had it tuned for a cold air intake, full exhaust, and 70mm throttle body (which ended up not being put on) the throttle body didn’t fit because it was for standard only. Now I replaced the throttle body gasket and Had to replace the tps as well. When I tried to plug in the new ecu and turned it on it sat at 2500 rpms bouncing. I couldn’t press the throttle more than 3,000 rpm and I couldn’t go into gear. Is there any ideas on to what could be wrong with it?
Old Dec 1, 2020 | 07:04 AM
shipo's Avatar
At this point you are pretty much on your own; your best bet would be to take your car to a shop which specializes in tuning modified cars.
Old Dec 1, 2020 | 07:25 PM
Do you have an old ECU that could run your engine? If yes, then try using the old ECU to see if the programming is the issue.
Old Dec 1, 2020 | 10:58 PM
Sdalton's Avatar
Well thank you guys but I did find someone in my area that specializes in Honda tuning and we talked about it
DIAMONDZ
Apr 22, 2013 12:10 PM
93jdmcb7
Jan 12, 2013 01:22 PM
Accord97
Nov 7, 2012 07:19 PM
f22b1accord
Feb 13, 2008 02:30 PM
johnny_1203
Aug 2, 2007 10:57 PM
