clacking when braking
Old Nov 22, 2006 | 01:16 PM
oufy's Avatar
Default clacking when braking
Starting yesterday i noticed a clacking sound from the front of the my 97 accord lx when I push the brakes lightly. This sounds isnt there when i push the brakes hard and the car stops quickly. It only happens when i push on the lightly and its a repetitive clacking. Could this be the engine muntng that needs replacement as there are alot of squeaks when i go over huge bumps. Any ideas and help would be great. Thanks
Old Nov 22, 2006 | 08:04 PM
lightshow's Avatar
Default RE: clacking when braking
probably a combination of warped rotors and bad pads. purely a brake issue. if you motor mounts go out your steering wheel will shake at idle especially with the a/c on.
Old Nov 23, 2006 | 02:03 AM
Chiovnidca's Avatar
Is it more noticeable at very low speeds? Warped rotors can cause the pads to move in the saddles causing a creaking noise.
flippinjig
Apr 12, 2009 07:28 PM
tambler
Jun 20, 2007 04:31 PM
maro
Jan 19, 2007 03:40 PM
sharapova4lyfe
Jan 19, 2007 11:45 AM
barrage
Jan 6, 2007 01:20 PM
